In GL->General Journal->In lines->I have so many records to insert.
So when inserting new record i am pressing DOWN arrow key .But after creating some records sometime when press DOWN arrow key,cursor moves to some 1st or some other row which it should not go.
Why it 's happening like this ? i have thousand records to do entry.And i am doing it as a USER.
No license code for to do some job and insert all thousand records.
I have to go the form and manually do the entries one by one by pressing DOWN arrow and tab.
The standard behavior is when you press down arrow in a grid form(provided:cursor must be in prev row),new record will be created.For example you created 1st ,then pressed down the arrow key 2nd row will be created.
