Hi all I have a problem I have to send some data to WebServer now i have problem with some characters like ä,ö,ü I tried to format them with this routine: // ASCII Strings to Converte ASCIIChar[1] := ‘"’; ASCIIChar[2] := ‘&’; ASCIIChar[3] := ‘Ä’; ASCIIChar[4] := ‘Ö’; ASCIIChar[5] := ‘Ü’; ASCIIChar[6] := ‘à’; ASCIIChar[7] := ‘â’; ASCIIChar[8] := ‘ä’; ASCIIChar[9] := ‘ç’; ASCIIChar[10] := ‘è’; ASCIIChar[11] := ‘é’; ASCIIChar[12] := ‘ê’; ASCIIChar[13] := ‘ò’; ASCIIChar[14] := ‘ö’; ASCIIChar[15] := ‘ù’; ASCIIChar[16] := ‘û’; ASCIIChar[17] := ‘ü’; // Replaced with this ISO Strings ISOChar[1] := ‘"’; ISOChar[2] := ‘&’; ISOChar[3] := ‘Ae’; ISOChar[4] := ‘Oe’; ISOChar[5] := ‘Ue’; ISOChar[6] := ‘a’; ISOChar[7] := ‘a’; ISOChar[8] := ‘ae’; ISOChar[9] := ‘c’; ISOChar[10] := ‘e’; ISOChar[11] := ‘e’; ISOChar[12] := ‘e’; ISOChar[13] := ‘o’; ISOChar[14] := ‘oe’; ISOChar[15] := ‘u’; ISOChar[16] := ‘u’; ISOChar[17] := ‘ue’; // Loop Thru and Replace FOR i := 1 TO ARRAYLEN(ASCIIChar) DO BEGIN REPEAT Pos := STRPOS(_Text,ASCIIChar[i]); IF Pos > 0 THEN BEGIN _Text := COPYSTR(_Text,1,(Pos-1)) + FORMAT(ISOChar[i]) + COPYSTR(_Text,(Pos + 1),1024); END; Pos2 := STRPOS(_Text,FORMAT(ISOChar[2])); UNTIL (Pos = 0) OR (Pos2 <> 0); END; The Problem i if i send the “ä” as #228; or ä it would be displayed corect on the WebInterface but the server can’t work with this. So our customer told us to send just a byte with the value 228. And i have now clou how i schould zo this correct. has anybody a good idea or a hint? Thanks Darki
You probably just need to convert the chars: Download this code unit, and you should be able to use that! http://www.mbsonline.org/forum/dwnl_show.asp?dwnl_id=35&cat_id=25&parent_id=6&sub_name=Components+usable+with+Navision&parent_name=Tools+For+Developers
