I am setting up security for user groups. Currently, whenever a user wants to run a report or comes across a dialog box from where the user can press the ‘Select’ button to access the Filter screen for that report, the Select button is not there.
For example, if I want to run the General Ledger report - Print Journal - in the dialog box for that report the Select button is missing - which security key enables the Select button to appear please?
It happens for all user groups except users in the Admin user group. We are still not Live yet in AX, so am still implementing, but I need to figure this out before we go live. Have been looking at it for a while and cant figure it out.
The button only appears for users who are in the Admin user group. All other users who are assigned to other user groups cannot see the Select button for any reports. Everyone is running the same application and kernel versions. If I move a user from a non Admin user group to the Admin user group, they can see the Select button. So it must be a security setting somewhere.
The solution was to create a new user group, assign ALL permissions to that group using the ‘Set All to Full Control’ option on form, then take out all the security one by one on all modules. Dont Cascade security down. This sould do the trick. Not sure why it is happening though, but it works.
