I found a lot of statistics in a customers database that I don’t recognize. It’s over 38K (!) rows in sysindexes which all have field names as the name of the stats. The name of these stats never contain “$” and they are not auto created. I guess someone hase been using the database tuning advisor or something similar.
So what’s the deal here? Should I just remove all these statistics so I just have those containing an “$” in the name left? I think I should, but I thought I could collect some input first since there’s over 38K of them in the database…
Best x-mas wishes from a really snowy and cold Sweden!
The id for the sales line table in one of the companies are 1269761218.
If I run this: “select * from sysindexes where id = 1269761218”
I will get this (I hope it’s readable):
id
status
first
indid
root
minlen
keycnt
groupid
dpages
reserved
used
rowcnt
rowmodctr
reserved3
reserved4
maxlen
maxirow
OrigFillFactor
StatVersion
reserved2
FirstIAM
impid
lockflags
pgmodctr
keys
name
statblob
maxlen
rows
1269761218
2066
0x58CE77000300
1
0x9ACE77000300
956
3
2
20717
26957
26888
82843
1226
0
0
2048
39
50
0
0
0xFA1602000300
0
0
0
NULL
MyCompanyName$Sales Line$0
NULL
8000
82843
1269761218
2
0xC05678000300
2
0x225978000300
22
12
2
1121
1139
1133
82843
1226
0
0
126
98
50
0
0
0x291702000300
0
0
0
NULL
$1
NULL
8000
82843
1269761218
2
0x887478000300
3
0xCA7478000300
9
8
2
674
691
681
82843
1226
0
0
101
73
50
0
0
0x3B1702000300
0
0
0
NULL
$2
NULL
8000
82843
1269761218
2
0x887778000300
4
0xCA7778000300
13
10
2
857
873
865
82843
1226
0
0
127
99
50
0
0
0x4B1702000300
0
0
0
NULL
$10
NULL
8000
82843
1269761218
96
NULL
5
NULL
0
1
0
0
0
0
0
1226
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Document No_
NULL
8000
0
1269761218
2
0xB07B78000300
6
0xF27B78000300
9
7
2
678
694
684
82843
1226
0
0
79
51
50
0
0
0x531702000300
0
0
0
NULL
$5
NULL
8000
82843
1269761218
96
NULL
7
NULL
0
1
0
0
0
0
0
1226
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Line No_
NULL
8000
0
1269761218
2
0xB87E78000300
8
0xFA7E78000300
22
12
2
1121
1139
1133
82843
1226
0
0
126
98
50
0
0
0x631702000300
0
0
0
NULL
$7
NULL
8000
82843
1269761218
96
NULL
9
NULL
0
1
0
0
0
0
0
1402
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
No_
NULL
8000
0
1269761218
96
NULL
10
NULL
0
1
0
0
0
0
0
1402
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Location Code
NULL
8000
0
1269761218
96
NULL
11
NULL
0
1
0
0
0
0
0
1401
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Shipment Date
NULL
8000
0
1269761218
96
NULL
12
NULL
0
1
0
0
0
0
0
1408
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Shortcut Dimension 1 Code
NULL
8000
0
1269761218
96
NULL
13
NULL
0
1
0
0
0
0
0
1401
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Bill-to Customer No_
NULL
8000
0
1269761218
96
NULL
14
NULL
0
1
0
0
0
0
0
1226
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Drop Shipment
NULL
8000
0
1269761218
96
NULL
15
NULL
0
1
0
0
0
0
0
1226
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Currency Code
NULL
8000
0
1269761218
96
NULL
16
NULL
0
1
0
0
0
0
0
1227
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Variant Code
NULL
8000
0
1269761218
96
NULL
17
NULL
0
1
0
0
0
0
0
1226
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Product Group Code
NULL
8000
0
1269761218
2
0xB88378000300
18
0xFA8378000300
9
7
2
633
643
639
82843
1226
0
0
89
61
50
0
0
0xB31702000300
0
0
0
NULL
$8
NULL
8000
82843
1269761218
96
NULL
19
NULL
0
1
0
0
0
0
0
1401
0
0
0
NULL
0
0
0
NULL
0
0
0
NULL
Sell-to Customer No_
NULL
8000
0
1269761218
2
0xB88678000300
20
0xFA8678000300
22
11
2
942
953
951
82843
1226
0
0
114
86
50
0
0
0x111802000300
0
0
0
NULL
$3
NULL
8000
82843
All these stats have status 96. Auto stats have been turned off and all created auto stats (WA_Sys) has been removed. I such a case there’s normally only statiscs with the same names as the indexes in the databas, but in this case there’s a lot of other statistics with field names as name.
That looks to me like someone who doesn’t know what they are doing ran some sort of ‘create missing indexes’ script on that database.
If you don’t KNOW what you are doing, then I don’t think you should be doing anything to fix it either. Don’t just start removing indexes because “their names don’t look right”. At the very least create a new database and import those objects into another location so that you can verify which indexes are supposed to be there according to the object design.
I didn’t know that statistics are stored in a table called ‘sysindexes’. I use an external tool to look at that information.
If it is indeed statistics then probably someone ran sp_createstats. If you can verify that the fields are all index columns then they ran sp_createstats ‘indexonly’, and you will want to leave those stats in there. As long as your database does not have autostats, and you have a daily job to update statistics, those stats actually help SQL Server.
Lars, do a simple and no-risk test by manually collecting statistics for one table:
Isolate your query for a single table.
In a separate query window, manually collect statistics for that table and its associated objects. For example: “update statistics dbo.mytable with fullscan, all”
Run your query again for that table.
A few notes on the specified command:
It does NOT specify the NORECOMPUTE option, such that if AUTO_STATISTICS_UPDATE was disabled for the table then the command above will reenable it.
It collects statistics for everything including even non-indexed columns. This simply gives the cost-based optimizer more information when creating an execution plan for a SQL statement. I’ve never had a problem doing this. It just simply make take more elapsed time.
It does a full scan, which is equivalent to a sample size of 100%. Again, I’ve never had a problem with this - just takes more elapsed time.
If this gives the desired result, you can run a script to perform this command for every table in the database(s), or you can simple run the Update Statistics task in a Maintenance Plan.
