I am new to Ax. I have a major problem which I can’t realy identified, made me MAD. I have a lookup in grid. When I am trying to select the lookup, the whole form with development environment getting closed …:(.
Sounds like you’re crashing the client when you try and do the lookup. Put a breakpoint in your code and see what line is crashing the client. Then debug that line…
