hi all ,
any one pls suggest me some links to do the version control setup for ax2009,
am i want to install any components ???
pls help me
thanx in advance
hi all ,
pls help me
thanx in advance
Hi Arun,
Run ax update of SP1 and Roll up.
More info on version details are here:
http://blogs.msdn.com/b/emeadaxsupport/archive/2009/07/01/overview-ax-kernel-build-numbers.aspx
Version Control System on MSDN is probably a good starting point. Using the Version Control Integration with Microsoft Team Foundation Server may be useful too if you decide to use TFS.
Configuration and prerequisites vary significantly depending on which version control system you choose.
hi tittly ,
thanx for u r reply,
i want to know the setup for VSS ,
i already installed SP1 and Rollups
