Hi kranthi,
the below code i was used in excel import. its working fine for me.
public void DataImport(LTCostValue _ltCostValue)
int insertcount= 0;
int row = 1;
Name Division,Department,Section;
MainAccountNum mainAccountId;
real Amount;
str COMVariant2Str(COMVariant _cv, int _decimals = 0,int _characters = 0,int _separator1 = 0,int _separator2 = 0)
switch(_cv.variantType())
case (COMVariantType::VT_BSTR):
return _cv.bStr();
case (COMVariantType::VT_R4):
return num2str(_cv.float(),_characters,_decimals, _separator1,_separator2);
case (COMVariantType::VT_R8):
return num2str(_cv.double(),_characters,_decimals,_separator1,_separator2);
case (COMVariantType::VT_DECIMAL):
return num2str(_cv.decimal(),_characters,_decimals, _separator1, _separator2);
case (COMVariantType::VT_DATE):
return date2str(_cv.date(),123,2,1,2, 1,4);
case (COMVariantType::VT_EMPTY):
return “”;
default:
throw error(strfmt("@SYS26908",_cv.variantType()));
return “”;
dialog = new Dialog();
dialog.caption(“Select File”);
fileName = dialog.addField(extendedTypeStr(FilenameOpen));
dialog.run();
application = SysExcelApplication::construct();
workbooks = application.workbooks();
try
workbooks.open(fileName.value());
catch
throw error(“File cannot be opened”);
workbook = workbooks.item(1);
worksheets = workbook.worksheets();
worksheet = worksheets.itemFromNum(1);
cells = worksheet.cells();
do
row++;
mainAccountId = COMVariant2Str(cells.item(row,1).value());
division = COMVariant2Str(cells.item(row,2).value());
Department = COMVariant2Str(cells.item(row,3).value());
Section = COMVariant2Str(cells.item(row,4).value());
Amount = any2real(COMVariant2Str(cells.item(row,5).value()));
ttsBegin;
costAllocationUploadTrans.clear();
costAllocationUploadTrans.LTCostValue = _ltCostValue;
costAllocationUploadTrans.MainAccountId = mainAccountId;
costAllocationUploadTrans.Division = Division;
costAllocationUploadTrans.Department = Department;
costAllocationUploadTrans.Section = Section;
costAllocationUploadTrans.Amount = Amount;
costAllocationUploadTrans.insert();
ttsCommit;
comtype = cells.item(row+1, 1).value().variantType();
while (comtype != COMVariantType::VT_EMPTY);
application.quit();
Main() code:-
public static void main(Args _args)
FormRun caller;
FormStringControl formcontrolCostValue;
LTCostValue ltcostValue;
FormDataSource formDataSource;
LTCostValueUpload ltCostValueUpload;
LT_CostValueUpload load = new LT_CostValueUpload();
ltCostValueUpload = _args.record();
load.DataImport(ltCostValueUpload.AllocationId);
formDataSource = _args.record().dataSource();
formDataSource.research(true);
Thanks for suggest to me!!!
