Hi all
I am trying to find out if we have found a bug in Dynamics AX SP1 or whether there has been some development work that needs removing:
Basically, when you update the header of a SO or PO an option prompts for updating the order lines (these are set via SO–>Setup–>Parameters and PO–>setup–>Parameters and can be be set for account change, warehouse change etc etc).
Our issue is - if you set say update warehouse to prompt and tick the box to update warehouse, amend an order header and change the warehouse - the process not only updates the warehouse on the order lines but updates everything else as well, including manually priced products. Hence we lose the original price. I would only expect the warehouse to update as the parameter only says warehouse.
This occurs across all the various options.
Is is standard practice or developed - unfortanately I do not have a standard install to look at
Hope this makes sense
Tony
