how can i slide the records when clicked up/down button on grid. The following is the relevant code
Thank you for your help.
static void moveRecordUpDown(FormDataSource _fds, HEX_SampleLabel _SampleLabel, boolean _up = true)
HEX_SampleLabel SampleLabel;
InventQualityOrderTable qualityOrderTable;
HEX_SampleNo oldSampleNo, newSampleNo, maxSampleNo, minSampleNo;
oldSampleNo = _SampleLabel.SampleNo;
if(!_up)
select maxOf(SampleNo) from SampleLabel
where sampleLabel.RefQualityOrderId;
maxSampleNo = SampleLabel.SampleNo;
if(oldSampleNo == maxSampleNo)
return;
select firstonly SampleNo from SampleLabel order by SampleNo
where SampleLabel.SampleNo;
newSampleNo = SampleLabel.SampleNo;
else
select minOf(SampleNo) from SampleLabel
minSampleNo = SampleLabel.SampleNo;
if(oldSampleNo == minSampleNo)
return;
select firstonly SampleNo from SampleLabel order by SampleNo desc
where SampleLabel.SampleNo < _SampleLabel.SampleNo;
try
ttsbegin;
SampleLabel = HEX_SampleLabel::find(newSampleNo, true);
SampleLabel.reread();
_SampleLabel.selectForUpdate(true);
_SampleLabel.reread();
_SampleLabel.SampleNo = newSampleNo;
_SampleLabel.update();
SampleLabel.SampleNo = oldSampleNo;
HEX_SampleLabel::arrangeTmpLineNo();
ttscommit;
catch (exception::Error)
throw error(“ERROR”);
