If i click the button, the selected line value(record) in the Grid should be inserted as new record
- If i click the button then selected line should be split as two record(Based on the Table numeric Field value(If that Field value = 5 means, after divided the first record that Field value = 3 and another one will be 2.
How to achieve this 2 solution…?
For the first question, take the current records selected and insert it in the same grid datasource.See the example code below.
Void clicked()
InventItemGroup inventItemGroup, inventItemGroup1;
Str itemgroup;
MultiselectionHelper helper = MultiselectionHelper::construct();
Helper.parmdatasource(InventItemGroup_DS);
inventItemGroup = helper.getFirst();
While (inventItemGroup.Recid! = 0)
//Info(inventItemGroup.ItemgroupId);
//Insert the selected line in the same datasource
inventItemGroup1 = inventItemGroup. ItemgroupId;
inventItemGroup1.insert();
inventItemGroup = helper.getNext();
Can you elaborate the second question?
Thanks Anand.
I got result for my first question from your ans.
Second one is
If i click the button, the selected line should be split as two record like 1st Question(Insert a duplicate Record). And Also one more requir. which is That Table has Field “NoPieces” with int DataType.
If this NoPieces = 5 means, automatically Insert a duplicate Record and the First Record NoPieces Value is change to 3 and Duplicate will be 2.
original :
id name NoPieces
101 power 5
if click Button, it converts to
id name NoPieces
101 powder 3
101 powder 2
if NoPieces 9 means
id name NoPieces
101 powder 5
101 powder 4
if NoPieces 1 means, Dont Allow to Split…
How is the splitting of pieces going on?
I mean,will the splitting be done manually or is there any formulae for that?
Thnx Anand…
I have done by using dialog box with ur above coding…
