Dear all
I make a customization in Inventory Transfair order form to show unit for each item
Unit conversion KG to TON and vice versa it is done in Items Movement
And needed to be done in Transfer Orders.
Ex: I have item named”X” its inventory unit is “TON”
When I make a transfer to another warehouse I want to transfer just “100KG”.
Now I have a problem that i want to calculate the conversion like sales order details form in Lines Grid
How can i do this ?
Generally When you transfer,issue stock from the inventory - the system considers the stock keeping unit…You will not be having an option to select the Unit.
Have you verified the effect of this customization in the Inventory?
Can you explain in detail the problem that you are facing at sales - where you have an option to select the Unit…
Dear Kranthi ,
I Added item Unit in transfair order , the problem that if i transfared 100 Kg but the main unit is TON the system see it as TON not KG
Dear All,
Here i mad item unit for Transfair order , but i need to know how to make Unit conversion .
