Hi guys i have item has proplem in unit of measure it is by kg and i need it by ton so that i close all open entries until inventory value become 0 after that i try to change item unit of measure from kg to ton it give me error "qty.per unit of measure must be 1 in item unit of measure item no xxx code ton"how i solve this proplem.
Accordingly, if you want tons to be the base UoM, set Qty per UoM = 1 for TON, and, accordingly, 0.001 for KG. In your case it is better to create a new Item, otherwise there will be a mess with quantities between historical and new data.
Usually it is recommended to use as base UoM the smallest possible one - to avoid using multipliers less than 1. With weight in metric tons/centners/kgs it is not so critical, but when we come to PCS, problems arise. For example - if a BOX is set up as base UoM, what to do if it contains 3, 6, 12 etc PCS and you wish to count your inventory by peaces?
When create new item it give me error message “you cannot delete item 1hgh because it has ledger entries in fiscal year that has not been closed yet” why this problem made it must accept but i dont know why
i close open entries until remaining is 0 and also remove application from worksheet then reapply it
when i rename old item it give me this error .1hgh is another item.different with i try to rename it
