Hi guys i have problem when i make return order to sales order then make function - copy document select posted invoice
and select invoiced sales order document then OK
message error show to me :
www.mediafire.com/…/sales_return_proplem.bmp
and this is code in debugger
www.mediafire.com/…/sales_return_order_code.bmp
My message error is :There is no sales price within filter
filter sales code ",item no xxx
How i solve this problem
thanks
Have you check whether price is defined in Sales Price for that Item?
Is there ant customization done ?/
Firstly no customization
In sales price table item code and customer name is already exist and i remove it and added again but no benefit
what i do now
my link is :
http://www.mediafire.com/download/1rda8ps5fiobme6/sales_price.bmp
the record is found in sales price table
but i don’t know why this error show
What is Start Date and End Date in Sales Price ???
Are two dates must be found or start date only
Is your price within the range of start date and end date of sales price for that Item and customer ??
I make start data before order date period and end data after date of order but also same error message still exist
are any solution to proplem
Check user setup date also who is posting the order.
I test all above but no benefit
but when i add item that make problem then assign sales code to all customers it accept
to make return order and message error not show
are this solution or wrong solution
thanks for help
Same question I asked you that whether that price is defined for that customer or not ?
yes defined i sure that customer and unit price found in table sales price within range as
start date 01-01-13 and end date 31-12-13 as following
asv0003500 customer je-tc-002388 250 01-01-13 31-12-13
as
unit price is 250
Now what i do to solve this proplem
thank you Amol the problem solved
my problem is i make check mark recalculate line when i make copy document in report 292 copy sales document
after i remove check mark it work only i leave include header check mark checked.
No need to start date and end date also
thanks
