The format of the Date does not match your device's date settings
i got the below error when trying to import a csv file - how do i change my device settings please
If requesting support, please provide the following details to help troubleshooting:
The format of the Datedoes not match your device’s date settings.
Make sure that the day, month, and year are in the correct order and use the correct separator (such as - or /). Alternatively, you can always use the format ‘yyyy-mm-dd’.
Good day,
While import the csv file, you need to change the date format as ‘yyyy-mm-dd’ in Excel.
Select the cell → Right click → Format cells → Go to date and set as mentioned format.
Guru Krishnan.
