Hi all, I am facing problem when I deploy ssrs from AOT It through an error ‘The network name can not found’ Kindly suggest AX2012 r3 Thanks in advance
Hi
1st solution:
Check if the ax 2012 AIF services are running or not!!!
2nd solution:
Or check if the c$ is shared or not!!!
See once below link
Thanks for quick reply
It seems to be ok for other reports it’s ok
But for this report inventtransfer report it showing error
Again deploy from visual studio, and add your report to AOT.
You can find add to AOT on report model, so the report will be added to AOT.
… this is xpo which i export from test server to live in test server looks ok but on live having error
Validate your connection first from System Admin … then Browse report server if all well then try to Import ur XPO
There may be a missing references and I would n’t carry the VS projects in XPO formats importing or exporting, You can deploy VS Projects/Reports from anywhere on the netwrok by using AXC connection param. Try that and you should be good.
