SSRS fromDate - toDate parameter!.
Hi DAX Community,
I’m having a problem in SSRS parameter…
Ax Standard:
when you leave the SSRS parameter blank, AX infolog generate error “FromDate / ToDate parameter is missing a value”
I just want to ask how to set a default Date Parameter using SSRS …
Thank you,
r0bert
if you are using ax2012 u need to edit the report in visual studio , set the property ‘Allow blank’
of the parameter to true , build and redeploy your report again.
