I have try the following SQL, but found the error message ( Operand Type are not compatible with the operator )
Select SUM(LineAmount)
from salesLine
where salesLine.salesLine.ShippingDateRequested == “2/24/2011”;
from salesLine
Hi Michael,
Change the query to
select sum(LineAmount) from SalesLine
where SalesLine.ShippingDateRequested == 24\02\2011;
Naresh Kolli
Hi Naresh,
Thanks for your help. It work!!!
I would like to ask one more question, which data type is not need to use symbol " ", int, real, date ?
It is required only for the string data type…for the rest no need to use…
Thanks Naresh,
I would like to create a method for Date, is any method that when choose Date 10\2\2011, then it will return coming days,
11\2\2011
12\2\2011
13\2\2011
Hi Michael,
Directly u can add no.of days to the date
mkdate(10,10,2010)+1;
it gives next day…
if it is not , give me some more expalnation…
If you want to increase the date it can be done as suggested by Roshan…
Hi both,
What I want to do is ,
if I choose any days, it first show the first three date of that month.
For example:
Choose 1/1/2011. then 1/1, 2/1, 3/1 will be shown.
Choose 5/2/2011, then 1/2, 2/2, 3/2 will be shown.
But I dont’t know how to handle it, as the EDT is Date, I could not use substr or make day.
I didnt get you what your saying…
Hi both,
For example:
Use function Global::dateStartMth(Date) to get startday of the month,then add according to it…
Thanks for your help. [Y]
