Hi friends,
how to add splitters between two tables in a single form?
examples:
take two tables table1 and table2
then add two tables in form datasoure
then i want to add splitters between two tables
when i open a form,table1 and table2 will display in single form
thanks
Use SubForm on Main Form.
Just look at the sales order and Sales order Subform. You will get an idea.
admin1
November 3, 2012, 12:53pm
5
examples:
You posted this in the NAV developer forum. It’s obvious that it’s not NAV, but AX, so moved to the Dynamics AX Developer forum. I hope you will be able to find your answer here, as it always helps to post in the right forum.
Harish
November 7, 2012, 10:11am
6
Hi Murali,
Have a look at ‘\Forms\tutorial_Form_Split’.
