Hello,
i want to sort a variable field in ascending order in a list page.
Hello,
Hello Seema,
As per my experience , We cannot sort a logical data field in list page. If you want to sort it then firstly you have to add it in table permanently then only you can sort it.
Thanks & Best Regards,
I assume that you don’t mean that you want to sort the page on a variable that you created, but on a variable key in the table?
Have you tried to use SETCURRENTKEY and ASCENDING(TRUE)?
Which version is it? In some of the early page versions it was not possible
Thank You, But its not a variable key in the table.
You can only do that with a “real key”, just as Tanu wrote. So if you solved your issue by adding a key, then please click “This Helped Me” below his post. [:)] If not, please elaborate.
