SETCURRENTKEY
Does anyone know a way to specify a sort order such as ascending or descending using the SETCURRENTKEY command or any other for that matter? Running a report and printing from an integer data item and need to allow a sorting selection for a temporary table. Any Help is appreciated
Hello Jack, Try This : YourTable.SETCURRENTKEY(FieldX, FieldY, FieldZ); YourTable.ASCENDING(TRUE); You already had the answer in your question [;)] Cheers, Tarek
But, when you use temporary table in repors, only have primary key Best regards from bcn Salut!
Product specific questions should be asked in the product specific groups, please…
I have the same problem, but my question is can we sort a TEMPORARY TABLE? hoping for your reply.Thanks
