Hi everyone,
I have a form for which I want to skip certain records.
In the OnAfterGetRecord trigger, there is a code that calculates a decimal varaiable X.
I want to be able to display only the records for which X > 0.
How can I achieve that?
Thanks in advance
As far as I know there’s no way to skip record in a form (like how you should do in a report): a solution can be in OnOpenPage mark the records adding code like this:
IF FINDSET THEN
REPEAT
// Calculate decimal
MARK(X > 0);
UNTIL NEXT = 0;
MARKEDONLY(TRUE);
IF FINDFIRST THEN; //For auto-placement on first record
