Why would these both return different results? It’s a one company environment. Try on your system. The purpose is to get the number of orphaned DirPartyTable records.
static void Job14(Args _args)
DirPartyTable dirPartyTable;
CustTable custTable;
VendTable vendTable;
select count(partyId) from dirPartyTable
where dirPartyTable.Type == DirPartyType::Organization &&
dirPartyTable.dataAreaId == ‘ABC’
notexists join custTable
where custTable.PartyId == dirPartyTable.PartyId &&
notexists join vendTable
where vendTable.PartyId == dirPartyTable.PartyId &&
dirPartyTable.dataAreaId == ‘ABC’;
info(strfmt("%1", dirPartyTable.PartyId));
– SQL call with different values
SELECT DT.[NAME],
DT.[PARTYID] as ‘DirPartyTable.PartyId’
FROM [AX_Dev].[dbo].[DIRPARTYTABLE] DT
where not exists (select ACCOUNTNUM FROM [AX_DEV].[dbo].[CUSTTABLE] CT where DT.PARTYID = CT.PARTYID) AND
not exists (select ACCOUNTNUM FROM [AX_DEV].[dbo].VENDTABLE VT where DT.PARTYID = VT.PARTYID)
and DT.TYPE = 2
and DT.DATAAREAID = ‘ABC’
