I have written some set of procedures in SQL server and i’m execute procedures from AX and result are not consistent . If i execute same procedures from SQL server getting correct result.
Please help me out in this.
I’m sorry, but if you don’t give us any specific information, you can’t expect any answer. Begin with explaining the problem - what the inconsistency means, when it occurs etc. Then explain your implementation - show us your code and tell us how you run in and so on.
(Question moved from the Technical forum.)
