i want add restriction on posting of item journal as per location for that i have done following implementation:
usersetup table:91 created field :loc. area code 200 run table adding value to this field as red|blue|green
on item jounal onaction of post addid code as:
UserSetup.RESET;
UserSetup.SETRANGE(“Loc area”,Rec.“Location Code”);
IF UserSetup.FIND(’-’) THEN
BEGIN
CODEUNIT.RUN(CODEUNIT::“Item Jnl.-Post”,Rec);
CurrentJnlBatchName := GETRANGEMAX(“Journal Batch Name”);
CurrPage.UPDATE(FALSE);
END
ELSE
MESSAGE(‘USER NOT VALID FOR THIS LOCATION: %1’,“Location Code”);
now it not allowing to post user with location code as blue,and red on item journal it giviong me error message why so.
I think there is something wrong with your logic here. You want to prevent users with certain location code to post item journal, is that correct ?
If so, I recommend you to add a field (a boolean) in the Location table to identify which Location you want to block.
For example, you create the field “Allow posting item journal”, and you don’t check it for Blue and Red locations, and check it for the others.
Then, in the post action you do :
UserSetup.RESET;
UserSetup.SETRANGE("User ID",USERID);
UserSetup.SETRANGE("Loc area",Rec."Location Code"); //Rec can contain multiple Location Codes, so...
IF UserSetup.FINDFIRST THEN
BEGIN
Location.RESET;
Location.SETRANGE("Allow posting journal",TRUE);
Location.SETRANGE(Code,UserSetup."Loc area");
IF Location.FINDFIRST THEN
BEGIN
CODEUNIT.RUN(CODEUNIT::"Item Jnl.-Post",Rec);
CurrentJnlBatchName := GETRANGEMAX("Journal Batch Name");
END ELSE
ERROR('USER NOT VALID FOR THIS LOCATION: %1',"Location Code");
END ELSE
ERROR('User setup does not exist for %1, location : %2',USERID,Rec."Location Code");
Of course, you have to create every user who are likely to post item journal in the User Setup Table.
