Hello everyone!
Can you filter a table first with setfilter and once it’s filtered, filter again using setrange??
Thanks you very much in advance!
Hello everyone!
HI ,
I think You can But , If you Filtered a Field By SetFilter and Again Filter by same Field Then Second Filter Only takes Effect.
Like Example
Cust.SetFilter(Cust.“No.”,‘50000…’);
IF findSet then
Cust.SETRANGE(Cust.No,‘10000’);
The result would be No = 10000;
Hope You Understood Don’t Apply on Same field.
Hi!
Ok, thanks for the explanation. Understood it perfectly well!!
Raquel
SETRANGE is basically just a “wrapper” for SETFILTER - internally on the database request there is no difference.
