Please explain me setrange and setfilter functions of c/al with example.
Regards
NIshtha
Regards
NIshtha
Use this function to set a simple filter, such as a single range or a single value, on a field.
Whereas SETFILTER can have various operators like >, <, <> etc. :
This operator… |
Means… |
Range |
And |
Less than |
Less than or equal to |
Greater than |
Greater than or equal to |
Different from |
Forms a part of value |
I believe F1 (Online help) has explained both functions well. If still you have any doubt, please post it here
Hi ,
I am very new to navision and i am learning nav2009 C/al please explain with example (setrange and setfilter functions )
Regards
Nishtha
Ok.
Lets say you are interested in Customer table’s those record having No. value in between 1000 and 2000 then you can write following:
Customer.SETRANGE(“No.”,1000, 2000); // Rec.SETRANGE(FieldName, LowerRange, UpperRange)
The limitation of SETRANGE is that you can not define the operators here, just linited to minimum and maximum values, whereas in case of SETFILTER you can define various operators.
For example, if you are interested in all values other than 2000 then
Customer.SETFILTER(“No.”,’<>%1’,2000);// all values other than 2000
Customer.SETFILTER(“No.”,’>%1’,2000); //all values greater than 2000
Customer.SETFILTER(“No.”,’<%1’,2000); //all values less than 200
<=200 | >500
All less than or equal to 200 or greater than 500
