Is there such think in AX application: SESSION variable use like in web application?
In PHP you can manipulate session variables to store information for that connected user until his browser is close. In AX is there a way to store data that would be accessible after the form is closed? I would rather not save the information on a disk. Just to keep this data until they close the application.
Sessions in PHP deals with the stateless environment, which is not actually the case in AX. Until you close AX client, you’re in a single session. And by the way, you can do a lot of things without opening any form at all.
The actual question is where to store your data. There are some truly global classes that you could modify, such as Info class (accessed by infolog global variable). But changing these classes would cause you troubles with upgrades and it would be generally ugly. These classes actually hold instances of SysGlobalCache class that you can use for your purpose. See Global variables post on mfp’s blog for an example.
By the way, you recently asked about Map class - that’s how SysGlobalCache is implemented.
