If you want to generate an SSRS report as a Word document, from the code or by using the report dialog form, I recommend you to take a look at Docentric AX. This tool can speed up report development several times and bring some new possibilities such as Word output with 100% fidelity. The tool also removes common SSRS shortfalls and improves print destinations.
