How to Restore Deleted Record or Table or any other deleted data in AX 2009?
Thanks In Advbance[:)]
Deletion of data from AX will remove the data from Database even. So i don’t think it will be saved some where.
Try to see in your transaction log file, you can recover from there.
if you have transaction log backup, you can restore it.
if you are using any thired party database backup & restore tool (i.e Quest Lite speed or an other).you could do object level restore also.
