Hello,
I have created a report in Nav 2009 and I want it to appear under Reports> Financial Statement. Can anyone please advise how to do that?
Hello,
Hi teena,
You add your report in Navion Pane designer.
You go to the Menu Suit and design the Navision Pane Desinger and your report where you like.
Enjoy
The report appears on the server side but not on RTC. Do you know why? I compiled and saved but it’s not appearing in the list.
Hi teena ,
Have u add the report in Page Menu Suit ,
Just do the below steps
1.click at the Navigation Pannal
2.Press Alt + F12
3.Go to the particuler menu (Financials->General Ledger->Reports->Financial Statement)
4.Right Click and select create item
5.A new window wil be open
6.select Report as your Object Type
7.3Select your report ID
8.press Esc
9.it will ask you to save
10.Save and exit
Thats All
Thanksmarshal.J
I followed your steps but the report appears on the server only and not on RTC. Is there a configuration that I am missing?
Hi Teena,
You need to take the correct Menusuite.
-TR-
It worked. Thank you so much. I am getting another error now.[:’(]
When I click on the report I get the error message:
“The supplied server name is not valid.”
Do you have an idea?
