Fixed Asset balance report showing different results…In first run it gives the result…-1340.00.In next runs it gives same result 1400.00…
Any suggestions to solve this problem…
How about the third run and so on? Any changes to the report?
Have you tired to debug?
No changes …For the first time only it shows different value…After that the results same…
If you can reproduce it, please try to debug.
It shows same values while debugging…(First time- -1340 after …1400.00)
Does these values are calculated? If so have you tried to identify the difference in calculation between first and second run?
Actually values are calculated using multiple values from fields.So there is no possibility in comparing the values in first run and second run.
Can you explain better?
