When your driving table for the report is Bank account ledger entry, why are you using a datefilter variable, you can directly use the Posting date field from the Bank account ledger entry table to accept user input from the user and your Bank account ledger entry table will be automatically filtered for the given date range.
Yes I did that but it was not working, that was why i used that approach. According to List Page, I have like seven with their unique number RC-00003,RC-00004, RC-00007, RC-00008 and RC-00010. After I filtered by Posting Date Which falls among them. It displayed only RC-00004 Report. Thanks
That is just not possible. When you use the Table itself the filters should work unless you have Maxiteration set to 1 or the Posting date in Bank account ledger entry is something that is outside the posting date you are filtering, in other words RC-00003, RC-0004, RC-00007 does not fall within the date filter you are filtering.
Ok, Since you are filtering Amount > 0 make sure that the above Document Nos. have Amount filled in otherwise it won’t show on your report. Please go to the Bank account ledger entry table and filter on Document no. RC-00003|RC-00004|RC-00007|RC-00009|RC-00010 and Amount > 0 and see how many lines do you see. My feeling is that since you are seeing only 1 line all the other documents have Amount 0.
On report print preview, click on the blue box arrow in the upper left corner of the preview screen, then select Help → About This Report
On the first attempt there will be no result, so close the report preview page and run the report again, then follow the steps mentioned above, and the xml data will appear
I will also suggest you change your date format for both the server and developer machine(client) to british date format, it appears to be in american date format
Contact me on monday via skype id : (danielduodupoku) for free direct assistance through anydesk remote software
Your picture is a little to small to see if it is the right lines you have in the XML output?
In that case then your problem is in the RDLC layout definition, which means that you need Visual Studio or SQL Report Designer to use it.
There could be many different reasons for this, it could be filtered in the data set or hidden per line. Or you may be using first(field) or last(field) instead of the correct field expression. If you have no previous experience with RDLC, then I suggest that you contact a senior or your partner.
