Recurring Journal
HELLO,
CREATED A RECURRING JOURNAL OF TYPE FIXED ONE DEBIT AND ONE CREDIT LINE THE NET RESULTS ZERO. EXCEPT WHEN I TRY TO POST IT SAYS THAT THERE IS AN AIMBALANCE. I DON’T WANT TO USE THE ALLOCATION ROUTINE PLEASE ADVISE ?.
THANKS
Look at DocNo - aren’t they different? Must be equal.
PS Please don’t CRY - or CapsLock stuck on your keyboard? (All caps is considered crying loud [;)] )
Doc No Identical for each line.
What exact message do you get?
Posting Date & DocNo must be the same, if amounts are equal it should post. Haven’t you ocasionally set different Currencies in your 2 lines?
lennyhenry;
Did you find the reason?
Please Take a look at the “Test Report” in Recurring Journal window, Navision will show you a warning message if at all something was entered incorrectly. Please tell us what the Error message is!!
Allocations are only used if you are Allocating the Cost by G/L by Dimensions. If not, why do u need it??
Kind regards,
Reddy.
