I need help with grouping
My company uses pallet tracking, and we frequently make adjustments to our output entries for date, quantity, and product corrections (those of you who don’t have the “Pallet Ledger Entry” and “Pallet Journal” cards, it’s similar to using the “Item Ledger Entry” and “Item Journal”). As a result, the ledger looks a lot like this:
Entry No. | Item No. | Posting Date | Prod. Order No. | Entry Type | Pallet ID | Lot No. | Quantity (Base) | |||||||
17478 | F5202-01 | 8/12/2007 | PR000027 | Output | 442601 | 7F5223 | 1 | |||||||
18291 | F5202-01 | 8/12/2007 | PR000027 | Negative Adjmt. | 442601 | 7F5223 | -1 | |||||||
18335 | F5202-01 | 8/11/2007 | PR000027 | Positive Adjmt. | 442601 | 7F5223 | 1 |
I have a corresponding custom report which is supposed to group the entries, leaving me with only the correct date, item, and quantity. I used http://dynamicsuser.net/forums/p/13265/65149.aspx#65149 to help create the grouping, but I still have problems. Here’s what the report INCORRECTLY prints:
Item No. | Posting Date | Prod. Order No. | Pallet ID | Lot No. | Quantity (Base) | |||||
F5202-01 | 8/12/2007 | PR000027 | 442601 | 7F5223 | 1 |
As you can see, the date is wrong. The report is set up as follows:
DataItem | Name | DataItemIndent |
Company Information | 0 | |
Production Order | 0 | |
Pallet Ledger Entry | 1 | |
Integer | 2 | |
Item | 2 | |
Item Variant | 2 |
The data prints from the Integer footer.
Anyone got ideas?
