I want to print a report at the end of the day using Web Services. So, I created a Codeunit with a function that calls this report and published it. In the Printer Selection, a default printer for this report is specified and following properties are set in the report- ShowPrintStatus=No, UseReqForm=No, UseSystemPrinter=Yes.
When I call the Web Service using C# routine, I get the following error “Callback functions are not allowed”.
I feel like we cannot print a report via Web Service even after suppressing the RequestForm. Is that true? Or, is there a way to do it?
Additional Info:
If I call a Processing Only report then, I don’t get this error.
This error generally occurs because the web service has accessed other application code that requires interaction with a client, such as a call to a client-side COM object.
To resolve this error, make sure that the web service call does not call code that requires interaction with a client, or modify your Microsoft Dynamics NAV solution to allow data to be inserted or modified without such interactions.
