pls help me in resolving the following issue i am facing after installing the hotfix KB Article Number (s) : 2929553 for Data Import Export Framework - AX 2012 R2 CU7.
when i click on PreSynchronise Step as per the software upgrade checklist. I am not able to Run (Run Button is not visible) the tasks inside the cockpit.
