hi,
would anyone know how the InventTrans table is being populated when a Pallet is being moved? this is done through the Inventory Management Module > Setup > Item equipment > Pallets > select a line of pallet > click Functions button > select Move Pallet menu item. I have to update the InventTrans.TransRefId when this functionality is used, however i can’t seem to find where the insert code to InventTrans table is located.
appreciate your help guys…
thank you very much…
