When I use the planning worksheet potentially hundreds of lines are created. If I use the field or table filters to reduce the worksheet to the items that I am interested in, when I ‘carry out action messages’ then all the lines in worksheet are actioned. Is this a bug or is there a logical reason for it to work this way ? Is this a simple modification. Thanks
Hi Navicons The filters do not go through to the routine of carrying out the action messages - you need to replicate them on the routine, essentially you are telling it not to filter by not refiltering, so it is not a bug, it is just doing what you are telling it to.
OK Thanks Steven. Sound like it should be a minor modification.
