Does anybody know a selection to return records by given selections in the way:
SELECT * FROM Table Where (Field1='A' **OR** Field2='B')
using native Navision. If I set filter to Field1 and Field2 they are combined together with and so Navision issues, to say so, a
SELECT * FROM Table Where (Field1='A' AND Field2='B')
Current I use two iterations, mark the matching records and use the result got by the function MARKEDONLY(). I don’t think this will be speedy with a greater number of records (>250000) [:(] Any suggestion (other than using the SQL Server option) ? Thanks in advance Arno Pucher
