If there is more than 1 record in the form and we are selecting the only one record in the check box but while clicking the button all the remaining records also get selected.But only one record should be marked in that check box. Can anybody help me to resolve this.
I saw the planned order form.But if we assign the edit method to that check box it is not allowing to select that check box.Then how can i click the button in that form without selecting the check box.
For simple understanding you can look into VendOpenTrans form(Open it from AP → Vendor details → Functions → Open transaction editing). Try to find out what is happening when the Mark Payment button is clicked in the form.
I am having one master form in that one button is there.While i am clicking that button and creating the new record it will insert the unique field which is populated from the master form then again if i am inserting a another record in that it should not allow to create and save.But in my case it is throwing the error but when i close the form and open it then the blank record is there.Can anybody tell me how to resolve this.
In the child form create a relation with the unique key you have. This will solve your first problem so when you click on the button the selected record
in the main form will be inserted. In the child form datasource property set create and delete to NO. So that the user will not be able to create a new record.
for the checkbox create a new field in the table type should be enum and in the form desig level create a checkbox control and in the properties of this control
specify the enum field which you had created previously and the datasource name.
