Hi all
I’va a problem using SQL ODBC from (Access 97/200x) to our (migrated a short time ago) SQL Navision Database.
Scenario:
-Windows 2003 Server Enterprise ENG
-SQL Server 2005 Enterprise SP3 ENG
-Navision Database: version 4.02 SP2
-Navision Server : 5.0 SP1 ITA (sql)
-Navision Client : 5. SP1 ITA
When connecting a numeric field type with an accuracy of 38.20 from a Navision table through odbc sql the value returnd of connected field is formatted into text:
Example:
Field: Standard Cost
Original Value :5,00002345
Result through ODBC Native : 5,00002345 (Numeric)
Result through ODBC SQL : 5,02 (Text)
I’m newbies on this, after searching the web results are that changing from odbc native to sql
modify many things but I cannot found what must do about the above issue for a one time solution…
… is there a way to set the driver at server side instead using CAST or similar function alltime by client side ?
I’ve read this discussion http://dynamicsuser.net/forums/p/14832/71306.aspx#71306
but not help. sorry
Any Help ?
