I have transdate field that is today date, and have to be return date field.
If a book is subscribed today user need to return the book with in 4 weeks if the pages is more than 1000, if it is less user need to return with in 2 weeks.
How can i write my method for above condition in table level
No its not getting the return date…
I write in validate write method as
public boolean validateWrite()
boolean ret;
AX_BookMaster axb;
AX_SubscriberLine axs;
ret = super();
if(axb.Pages>‘1000’)
this.TobeReturnDate= axs.TransDate+(47);
else
this.TobeReturnDate=axs.TransDate+(27);
return ret;
when I gave the transdate it is displaying as 15/11/90
You shouldn’t be doing it in validateWrite() method.
Override modified field on table and write a case for TransDate
this.TobeReturnDate= this.TransDate+(47);
else
this.TobeReturnDate=this.TransDate+(27);
You are not selecting axb record. So it will always goes to else, you need to find the axb record before doing it.
i already wrote one modified field method as
public void modifiedField(fieldId _fieldId)
AX_SubscriberLine axsl;
super(_fieldId);
if(_fieldId==fieldnum(AX_Transaction,Book_Id))
select axsl where axsl.Book_Id==this.Book_Id;
this.Sub_Id=axsl.Sub_Id;
this.TransDate=axsl.TransDate;
how can i override again in modifield field method.
Then you don’t have to override it. Modify it.
switch(_fieldId)
case fieldNum(fieldnum(AX_Transaction,Book_Id)):
break;
case fieldNum(AX_Transaction, TransDate):
// place your logic here
break;
You should be knowing the relation between current table and AX_BookMaster
Example - select firstonly pages from axb where axb.Book_Id == this.Book_Id;
AX_Subscriber table with subscriber id, name and address
I have the subscriberlines in another table with fields SubscriberId,BookId and transdate as today date.
I create relation in subscriberline table to bookid and subscriber id.
Now I created another table as Transaction table to mention the tobereturndate of the book and status as checkin, checkout…
When the book is subscribed it need to change the status as checkout and when it is returned it need to change as checkin.
in transaction table i tried to write the modified field coding as you mentioned:
AX_BookMaster axb;
super(_fieldId);
switch(_fieldId)
case fieldnum(AX_Transaction,Book_Id):
break;
case fieldNum(AX_Transaction, ToBeReturnDate):
while select pages from axb where axb.Book_Id==this.Book_Id
this.TobeReturnDate= axsl.TransDate+(47);
else
this.TobeReturnDate=axsl.TransDate+(27);
break;
but it is not getting the return date please give me the exact coding…
In subscriberline i need to give validation as customer can’t subscribe more than 4 books:
I write validatewrite method as follows:
boolean ret;
ret = super();
while select count(Sub_Id) from axs
if(axs.Sub_Id>=‘4’)
warning(“User can’t subscriber more than 4 books”);
return ret;
But it’s storing the record of book_id i’m giving more than 4 times, please help
else
break;
