if(this.fromdate && (this.todate >> this.fromdate))
This.reqdays = any2str(this.todate- this.fromdate);
Else
Throw error (“Todate must be grater than fromdate”);
above code is not working
can u plz guide me!!!
Else
Hi Ven Benz,
try this…
static void Job19(Args _args)
TransDate fromDate,toDate;
int reqDays;
fromDate = mkdate(01,07,2011);
toDate = mkdate(19,07,2011);
if(fromDate && (toDate > fromdate))
reqDays = todate - fromDate;
else
throw error(strfmt(“To-date %1 must be greater than from-date %2”,todate,fromdate));
info(strfmt("%1",reqDays));
Naresh Kolli
this.RequestedFromTime = timenow();
if(this.RequestedToDate && (this.RequestedToDate >this.RequestedFromDate ))
this.RequestedDays = this.RequestedToDate - this.RequestedFromDate;
else
throw error("To-date must be greater than from-date ");
In above code I am first entering this.RequestedFromDate the next step its showing error with out entering RequestedToDate
Hi Ve Benz,
You are giving only the this.RequestedFromTime,but in the if coniditon you are checking for the this.RequestedToTime…so if it is not it obviously shows the error…If this is case you need to give the RequestedToTime also…
If this is not the case, can you can explain it in details…
Naresh Kolli
Where you have placed this code?
i wrote the code in Table level modifiedfield method
now i changed code
if(this.ApprToDate && this.ApprToDate < this.ApprFromDate)
throw error(“ApprFromDate Must be greater than ApprFromDate”);
if(this.ApprToDate && this.ApprToDate > this.ApprFromDate)
this.ApprovedDays = this.ApprToDate - this.ApprFromDate;
like this its working now
thanks for replays
thanQ;
