Need for help on Navision Communication Component
Hello, could anyone point me on good article with examples about communication with Attain 3.10 through ComCom from external application? I have read DevGuide and this forum, but still not understand, how to send or recieve data from Navision, for example, in Delphi. Sincerely, Konstantin
Hi Konstbel, Kindly go through the document w1w1codbc.pdf. That you can find in the doc directory of installation CD.
Thank you, Rajesh. I have already successed with C/ODBC, but I asked namely about Communication Components, that comes with NA 3.10
The best documentation is the the Commerce Portal implementation which uses the MSMQ adapter. 3.60 has a TCP/IP socket adapter, too. I haven’t worked with it yet so I can’t say if it’s good, bad, or ???.
