You can also try this using the field properties of table (Development Environment). Set the ‘Editable’ property to ‘No’. Thereby nobody will be able to edit any content of the table/Page.
You can try this using the field properties of the master table. Set the ‘Editable’ property to ‘No’ for the required fields and thereby nobody will be able to edit the contents.
