Greetings.
I’m attempting to join two tables within a Query object within an AL Extension. However the only link data between the two is the RecordRef.RecordID of table 1 stored in a “Record ID” field in table 2. I’ve tried referencing the “Record ID” field in table 2 with table1.RecordID as part of the dataitemlink, but the Query object won’t accept it.
Here’s what the code looks like:
query 50000 MyQuery
elements
dataitem(Table1; “Table One”)
column(fieldone, “field one”) {}
column(fieldtwo, “field two”) {}
dataItem(Table2; “Table Two”)
dataItemLink = “Record ID” = Table1.RecordID;
column(fieldthree, “field three”){}
Can I use RecordID to join between these two tables? Has anyone tried this linking tables using Record ID in a Query Object?
