Updating record from an outerjoin link in AX2012
Hi Guys,
I am facing an issue which I cannot see where I miss something.
I created a new table, which is a shared table, and has a relationship with InventTable. the new table that I created will be updated in EcoResProductDetailsExtended form, whenever the item is selected. Now, I added the new table as datasource in the form, with a relationship of outerjoin - cause other items might don’t have a record from this new table. For some item records, I can update it, but for some are not. It seems that it clear the link between the InventTable and the new table that I created.
Also, I added a code in validateWrite of my new datasource to initialize the itemId for the new table. Cause the itemId is required in saving the new record in the new table. I put a breakpoint to see if the validateWrite method is executed. It’s really weird cause for some item it can call the method, for other its not.
Any thoughts is highly appreciated.
Thanks.
