My requirement is to get the Item Ageing report as per the actual bucket . I know there is a standard report Item Age Composition - Value, and quantity, but the problem with this report is that it runs as per the current date. i.e based on Remaining quantity.
But what i want is too see the actual ageing similar to AR/AP.
Example :- If increase for month of march is 100 and out of this 100 i have a decrease of say 20 then whenever i run a report with ending date as 31st Match then it should 80 as balance in that bucket .
Currently working on modifying the Item Age Composition - Value report by taking Item application entry table as dataitem.
Just require your suggestion , if there is other to generate the report.
Faisal Bukhari
