Hello,
I am using excel “add tables” functionality to import Products data into AX 2012.
I am importing the following tables, in sequence:
EcoResProduct
EcoResProductIdentifier
EcoResDistinctProduct
EcoResProductTranslation - for product names
InventTable
InventItemGroupItem -for the association with an item group
InventModelGroupItem -for the association with an item model group
InventTableModule -for the association with purchase, sales, and inventory units
EcoResStorageDimensionGroupItem - for the association with a Storage dimension group
EcoResTrackingDimensionGroupItem- for the association with a Tracking dimension group
everything is publish just fine, however the last two tables; EcoResStorageDimensionGroupItem and EcoResTrackingDimensionGroupItem, give the following unexplainable error: " Document Generic document could not be updated. Error details: " nothing more.
how should i get around this error in order to import item associations with storage and tracking dimensions?
thanks
Hi
Please follow the following tables
EcoResProduct
EcoResProductDimensionGroupProduct-------------------à If Product Master
EcoResStorageDimensionGroupProduct
EcoResTrackingDimensionGroupProduct
InventTable --------------------------------------------------------à Release Product
InventItemGroupItem
InventTableModule ---------------------------------------------à Unit of Measure
EcoResColor
EcoResProductMasterColor
EcoResSize
EcoResProductMasterSize
EcoResConfiguration
EcoResProductMasterConfiguration
EcoResProductVariantColor
EcoResProductVariantSize
EcoResProductVariantConfiguration
EcoResDistinctProductProductVariant -------------------------------à Item Dimension Combinations
InventItemSetupSupplyType ----------------------------------------à Optional
ecoresproductcategory
Warm Regards
MS
Hi, I am importing “released products” in AX 2012. Does the above list all apply? Also, how can I use the excel add-in to import the files? Is there a blog or technet reference as I am relatively new to importing data using Excel in AX. Thanks
Hello Patrick,
i ended up using the Data Migration Framework tool by Microsoft. it worked like charm.
however make sure to test it on your test server first because its still in Beta.
after you;re done with it on the production server, remove the tool.
Rola
Hi Rola, thank you for your feedback. Appreciate it. That’s what I am moving toward. Since we are importing the items into “released product”, i am wondering which sample demo file that you referred to? There are product_basic and product_enum and there is nothing there for item (released product). Appreciate if you could clarify. Thanks a lot.
Actually the demo files for product are “ProductEntity_DimensionGroups”, “ProductEntity_PurchaseSalesInvent” . Do I need to generate a new source as I am importing into “Released Product”?
Hello Patrick,
when i imported products i made my own source file and built it based on test data provided by the customer. this is a better practice because the data of the customer might include some characters or information that can be incompatible, so you have to test for those using customer dummy data.
if you want to test on the contoso environment, i think you need to import both demo source files.
Hi Rola,
Haven’t you faced any problem with the default order setting when you imported your product list using Data Migration Framework?
Did you manage to import color dimension to your product also “color or size”?
Regards
