Does n1 have step wise guide to import “Product Variants” in ax 2012 through excel add ins.
Here is an article
Dear Kranthi,
Thanks for replying ,
I am using the same link as you provided in earlier post .
I have imported following tables sequentially ,
EcoResProduct
EcoResProductIdentifier
EcoResProductTranslation
EcoResProductMaster
EcoResProductDimensionGroupProduct
EcoResStorageDimensionGroupProduct
EcoResTrackingDimensionGroupProduct
EcoResProductMasterColor
EcoResProductMasterSize
EcoResProductInstanceValue
InventTable
InventDim
I have successfully imported above tables sequentially , some tables are not mentioned here as i was getting errors while importing those tables,
so could you plz mention the mandatory tables which I must have to import apart from the tables I have imported as above for variants.
(Mayur)
EcoResProductVariantColor, EcoResProductVariantSize…
EcoResColor, EcoResSize…
EcoResDistinctProductVariant.
InventDimCombination
For more information, see Item-Product data management framework in AX 2012
BTW, why cannot you use the DMF/DIXF, it has many out-of-box entities(variant is one among them).
If you have the DMF installed, look at Queries\DMFProdcutVariantTargetEntity
Classes\DMFProductVariantEntityClass
Yeah… many of the technicals suggested me to use DMF but I am instructed by my superior to use only excel add in NOT DMF dats y I cant use it.
as u guided i used the table " EcoResProductVariantColor " bt m getting the error .
I am sending the screen shot of my excel sheet and the status after I say publish to it .
in ProductVariants.ProductNumber field i am writing my product no. as PR0035.(Here nly some error ,i think i have to write some thing else.)
You need EcoResDistinctProductVariant as well. Look at the data model diagram in the white paper Item-Product data management framework in AX 2012
I would like to thanks " Mr. Kranthi " sir for helping and guideing me to import variants .
variants sucessfulyy imported[:D]
